Canon PowerShot SD450 Lens Assembly Replacement
Introduzione
Vai al passo 1This guide will walk you through a lens assembly replacement procedure.
Cosa ti serve
Strumenti
Mostra di più…
Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
Altre 5 persone hanno completato questa guida.
