Salta al contenuto principale
Canon PowerShot SD1100 IS Flash Assembly Replacement
Tyler Grossheim
Tyler Grossheim e 8 altri collaboratori
Ultimo aggiornamento il January 28, 2014
15 - 30 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Use the guide to remove the flash assembly.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Canon PowerShot SD1100 IS Flash Assembly Replacement, Front and Rear Cover: passo 1, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement, Front and Rear Cover: passo 1, immagine 2 di 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 2, immagine 1 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 2, immagine 2 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 2, immagine 3 di 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 3, immagine 1 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 3, immagine 2 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 3, immagine 3 di 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
    I had to remove the screw on the bottom mounting plate to get the front case cover off. The screw closest to the middle. The front plate does have a hole here that the screw goes through
    remove both screws - the second holds the back plate
    Michael Chalifoux - Replica
  4. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 4, immagine 1 di 1
    • The cases should now be removed.
    This can be a bit tricky when reassembling. All of the little tabs around the edge need to snap into their proper places, and there are three cover pieces to manage. Plus, you need to make sure that the camera/video/playback switch is properly engaged with its slider on the circuit board, otherwise you'll need to raise the back panel and reposition everything again.
    Craig Bonsignore - Replica
    oh yes , i agree lol
    elbala80 -
  5. Canon PowerShot SD1100 IS Flash Assembly Replacement, LCD screen: passo 5, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement, LCD screen: passo 5, immagine 2 di 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 6, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
    I used this guide for a blue "made in china" version of this camera, as well as a silver "made in japan" version. The L-shaped brackets on either side of the LCD were much easier to remove for the blue one, but I was able to get them out for the silver one also with some additional coaxing. There were more pronounced tabs/notches securing the brackets to the adjacent frame on the silver one.
  7. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 7, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 7, immagine 2 di 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
    There is a hole in the reinforced "plug" end of the LCD cable shown in Step 8. You can use a dental-type pick to remove and replace the plug easily.
    Edward Pinnell - Replica
  9. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 9, immagine 1 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 9, immagine 2 di 3 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 9, immagine 3 di 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 10, immagine 1 di 1
    • The LCD screen should now be removed.
  11. Canon PowerShot SD1100 IS Flash Assembly Replacement, Flash Assembly: passo 11, immagine 1 di 1
    • Remove the screw located on the side of the camera (0.072 in).
  12. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 12, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 12, immagine 2 di 2
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 13, immagine 1 di 2 Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 13, immagine 2 di 2
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 14, immagine 1 di 1
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
    I had trouble with the small hook here. I found it much easier to first remove the two screws on the back holding this metal piece in place.
    Jeff Churchill - Replica
  15. Canon PowerShot SD1100 IS Flash Assembly Replacement: passo 15, immagine 1 di 1
    • The capacitor should now be removed.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 3-32, Regan Winter 2011 Membro di Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Membri
8 Guide realizzate
2Commenti sulla guida
Step 14 The little hook at the bottom that holds the flash assembly in is hard to see. It is part of the bracket that holds the flash in and also forms part of the chassis of the camera. I found that you can gently flex the bracket outward ( away from the flash) to release the hook. After that, the flash unit came right out. Also note, that some flash units you get from electronics scrapers on ebay will have the bracket attached to the flash unit and it needs to be removed before you install the replacement part. It seems obvious but then again...
Jamey - Replica
How much would it be to get this fixed?
shelley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,228
