Canon PowerShot A2200 LCD Screen Replacement
Introduzione
Vai al passo 1This guide will require you to use a Phillips head screwdriver to remove the screws holding the screen in place.
Cosa ti serve
Strumenti
Mostra di più…
First, remove the batteries and memory card.
Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
Begin taking off the back cover with a plastic opening tool.
Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
Continue taking off the back cover along the left side of the camera as seen in the third picture.
Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
You will need a long stemmed #00 screwdriver to get to the bottom of the recess.
Gently lift of the buttons for replacement. They should come off without excessive force.
If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
there is a tang under the front of the frame which is a little stiff to release. but does not need excessive force.
Lift up the electrical ribbon shown to access the next screw.
Remove the 3.9 mm screw with a Phillips #00 screwdriver.
Locate ribbon flap, enclosed in red. (picture 1)
Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
To reassemble your device, follow these instructions in reverse order, starting with the last guide step.
Preparati per le riparazioni future
Acquista tutti
