Canon EOS Rebel G LCD Screen Replacement
Introduzione
Vai al passo 1This guide shows you how to install a new LCD screen.
Cosa ti serve
Strumenti
Mostra di più…
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
Preparati per le riparazioni future
Acquista tutti2Commenti sulla guida
Great guide thanks! I found my lcd screen was partially working, the top part of the display was showing incomplete numbers...Cleaning the lcd contacts and reassembling it fixed the issue! No need to replace the screen in my case!
What Kind of glue is suggested to replace the textured grip?
