Salta al contenuto principale
Canon EOS 6D Front and Top Body Panel Replacement
Justin Thomas
Justin Thomas e 6 altri collaboratori
Ultimo aggiornamento il 2 apr 2025
50 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the front or top body panels of your EOS 6D or to access damaged internal components.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon EOS 6D Front and Top Body Panel Replacement, Rear Body Panel: passo 1, immagine 1 di 1
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
  2. Canon EOS 6D Front and Top Body Panel Replacement: passo 2, immagine 1 di 1
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
  3. Canon EOS 6D Front and Top Body Panel Replacement: passo 3, immagine 1 di 1
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
    Presume includes same procedure for the right hand side of the camera which is now shown as derubberised
    laylow - Replica
    It is unnecessary to completely remove the rubber from the right side of the back panel - in the next step where you remove two screws, simply lift the top right corner for access.
    rakurai - Replica
  4. Canon EOS 6D Front and Top Body Panel Replacement: passo 4, immagine 1 di 1
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
    Phillips#0 seemed to be a more secure fit.
    John Hood - Replica
  5. Canon EOS 6D Front and Top Body Panel Replacement: passo 5, immagine 1 di 1
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
  6. Canon EOS 6D Front and Top Body Panel Replacement: passo 6, immagine 1 di 1
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
    Correction:
    2x 3mm Phillips #00
    1x 6mm Phillips #00 in battery compartment
    Joey Fresco - Replica
    Figure circle is not correct. Joey Fresco is right.
    Tomonori OTA - Replica
    the 6mm phillips #00 is under the grip.  The other 2 are 3mm.
    Jay Wang - Replica
  7. Canon EOS 6D Front and Top Body Panel Replacement: passo 7, immagine 1 di 1
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
  8. Canon EOS 6D Front and Top Body Panel Replacement: passo 8, immagine 1 di 2 Canon EOS 6D Front and Top Body Panel Replacement: passo 8, immagine 2 di 2
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
    The ribbon cable is connected to the camera via a plug (the gold colored PCB has a male plug on the other side of the PCB). This plug is at the end of the spudger. You need to pull that PCB boar/plug straight up from the camera (perpendicular to the camera)
    Jim R - Replica
    There is a metal piece protruding from the back panel into the main body, down near the battery door. DO NOT simply bend the back panel down 90 degrees! Gently pull the entire back (including the lower right corner near the battery door) straight away from the camera about 1cm, and then lower the back panel 90 degrees.
    rakurai - Replica
  9. Canon EOS 6D Front and Top Body Panel Replacement, Front and Top Body Panels: passo 9, immagine 1 di 1
    • Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
  10. Canon EOS 6D Front and Top Body Panel Replacement: passo 10, immagine 1 di 1
    • Rotate the camera so the side with the SD card slot is facing you.
    • Remove the 4mm Phillips #00 screw from the bottom edge of this side.
  11. Canon EOS 6D Front and Top Body Panel Replacement: passo 11, immagine 1 di 1
    • Rotate the camera so the bottom is facing you.
    • Two 8mm Phillips #00
    • One 4mm Phillips #00
  12. Canon EOS 6D Front and Top Body Panel Replacement: passo 12, immagine 1 di 1
    • Remove the bottom panel from the camera by using your fingers to pull outward on the tab inside the battery compartment.
  13. Canon EOS 6D Front and Top Body Panel Replacement: passo 13, immagine 1 di 1
    • Rotate the camera so the front is facing you.
    • Three 5mm Phillips #00
    • Two 6mm Phillips #00
    the screw on the grip is 4mm shorter then 2 on the right side.
    Jay Wang - Replica
  14. Canon EOS 6D Front and Top Body Panel Replacement: passo 14, immagine 1 di 1
    • One 4mm fine-thread Phillips #00
    • Two 4mm coarse-thread Phillips #00
    Screw types were wrong.   There is only one coarse-tread Philips on the botton.  The top two are fin-thread.
    Jay Wang - Replica
    Not on mine, the two orange-labeled screws were coarse threaded, but they are not the same length. The 0.5mm longer screw goes in the hole nearest the battery door.
    rakurai -
    Do not remove the upper orange-labeled screw. Removing the SD card door is unnecessary and risks damaging the tiny switch that detects the door being closed. Instead, loosen the screw about 1 turn and slide the front plate forward.
    rakurai - Replica
    If you damage the switch, use a utility knife to pry it off the board/cable it is connected to and it will “trick” the camera into thinking the door is always closed. Be sure to turn your camera off before removing the card if you do this.
    Owen - Replica
  15. Canon EOS 6D Front and Top Body Panel Replacement: passo 15, immagine 1 di 1
    • The red speaker wire is attached to the inside of the front panel. Opening the front panel forcefully may break it.
    • Slowly fold the front panel to the right without pulling it away from the right edge of the camera.
    The adhesive holding the “6D” badge can give some resistance, be careful as it is very close to the delicate speaker wire.
    rakurai - Replica
  16. Canon EOS 6D Front and Top Body Panel Replacement: passo 16, immagine 1 di 1
    • Remove the 4mm Phillips #00 screw on the inside of the front panel to separate the panel from the speaker wire.
    Can the lens mount ring (the EF mount ring with the red dot) actually be removed without having to remove the front panel by just removing the four screws? Or does one actually have to disassemble the whole camera as shown in this guide?
    John Paul Adrian Glaubitz - Replica
    Better to remove mount ring after disassemble the whole came as this guide. The ring was caught and could not be removed.
    Removing the front panel is unnecessary for removing the top case. Just pull the panel forward 0.5cm to unhook the top case from the pins in the front panel, then slide it back into position temporarily while you work with the top. This avoids needing to unhook the speaker or otherwise damage front components.
    rakurai - Replica
  17. Canon EOS 6D Front and Top Body Panel Replacement: passo 17, immagine 1 di 1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the strap hook.
    5mm screw, in case you unnecessarily removed the shutter button screw in the next step and mixed them up.
    rakurai - Replica
  18. Canon EOS 6D Front and Top Body Panel Replacement: passo 18, immagine 1 di 1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the shutter button.
    This step is not necessary
    Scott McRae - Replica
  19. Canon EOS 6D Front and Top Body Panel Replacement: passo 19, immagine 1 di 1
    • Rotate the camera so the top is facing you.
    • Remove the 6mm Phillips #00 screw from next to the analog screen.
  20. Canon EOS 6D Front and Top Body Panel Replacement: passo 20, immagine 1 di 1
    • Rotate the camera so the back is facing you.
    • Remove the Phillips #00 screw from the viewfinder focus.
    At no point did you tell us how to remove the mode dial.
    Matt Herriot - Replica
  21. Canon EOS 6D Front and Top Body Panel Replacement: passo 21, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Carefully detach the two light brown ribbon wires on the top panel:
    • The right ribbon by prying it out with the flat end of the spudger.
    • The left ribbon by using tweezers to gently wiggle it out toward the top.
    The ribbon connector indicated in orange has a lever on the back of the connector that you lift with the spudger to release the cable. Then reinsert the cable until you feel it hit home and close the lever.
    Scott is right.  To raise the lever is necessary when putting the ribbon back.
    Jay Wang - Replica
  22. Canon EOS 6D Front and Top Body Panel Replacement: passo 22, immagine 1 di 1
    • A ribbon wire connects the inside of the top panel to the body of the camera.
    • Slowly lift the top panel to about an inch above the body of the camera.
    • Carefully use the flat end of the spudger to detach the ribbon wire from the top of the camera.
  23. Canon EOS 6D Front and Top Body Panel Replacement: passo 23, immagine 1 di 1
    • Grip the remaining side panel with your fingers and gently pop it off the camera.
    This step is unnecessary and risks damaging the tiny SD card door switch. See my comment on step 14 above to avoid removing this part.
    rakurai - Replica
Conclusione
Altre 13 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Justin Thomas
Membro da: 04/22/14
2.188 Reputazione
6 Guide realizzate
Cal Poly, Team 11-48, Amido Spring 2014 Membro di Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
4 Membri
18 Guide realizzate
7Commenti sulla guida
Actually, it would be perfect to note the color of the screws throughout the manual. This would help to get it right!
But thanks anyway, you saved me!!
mrbakin - Replica
In step 11 one of the red circles marks incorrect screw - should point the one near plate not the one in battery compartment (compare to step 6)
leszekcylupa - Replica
Agreed.
But thanks, apart from this minor error it was a great help and really clear. Cleaned the gunge out of the menu button and it now releases perfectly.
I found getting the ribbon cable back in (step 21) a bit difficult, combo wiggled and pushed it back in. Might recommend doing that one before the right one, and maybe before finally mounting the top cover.
Blakey -
My DSLR don't want to start after remount :(
dlirsoon - Replica
Thanks.  You folks did a great job.  It help me replacing the main dial in 3 hours in just the first attempt.
Jay Wang - Replica
I have no power to the camera after reassembling the body. All cables have been replaced correctly and secured. Any ideas?
David Collen-jones - Replica
like a charm! you rock! thanks for that picture by picture howto, my camera got a new dail button after the ring with the icons was damaged and didn’t stick no more.
Albert Einstein - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 137
Tutti i Tempi: 17,945
