Salta al contenuto principale
Canon EOS 5D Mark II Clock Battery Replacement
Mike Seed
Mike Seed e 2 altri collaboratori
Ultimo aggiornamento il 20 mag 2022
5 minuti
Facile
Introduzione
Vai al passo 1
It is important to note that removing the memory battery will cause the camera to forget all of your settings. It would be helpful to document your settings before performing these steps. Perform these steps as basic troubleshooting, much like a soft reset.
Cosa ti serve
Strumenti
  1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: passo 1, immagine 1 di 1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Clock Battery Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000, remove the single 3.4 mm screw.
    You have gone this far, replace the battery anyway.
    I used a little blue tack to keep the screw in place
    Ron B - Replica
  3. Canon EOS 5D Mark II Clock Battery Replacement: passo 3, immagine 1 di 1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
    In this step you also should remove the black screws to the left end right of the memory battery screw. Otherwise you can not remove the in/out port plastic covering in step 6.
    Per Feet - Replica
Conclusione
Altre 16 persone hanno completato questa guida.
Mike Seed
Membro da: 09/22/14
3.115 Reputazione
8 Guide realizzate
USF Tampa, Team 1-6, Hickman Fall 2014 Membro di USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Membri
16 Guide realizzate
4Commenti sulla guida
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - Replica
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - Replica
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - Replica
No, because some faulty behavior i removed my clock battery from my 5D MK2, but the shutter count is still the same, it would be to easy to hack a camera to be sold on a good price. :)
Vass János Szilárd -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 117
Tutti i Tempi: 27,155
