CASIO CDP-230R Speaker Replacement
Introduzione
Vai al passo 1Speakers sometimes stop working or you may want to upgrade them. This guide shows you how to replace the two speakers on the front of the keyboard.
Cosa ti serve
Strumenti
Flip the keyboard upside down, with the keys on a flat surface.
Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
In my model CDP230, upon removing the inner most side panel, 2 screw brackets will come loose each side. It will fall somewhere behind - you will need these when closing once again the panels. It has its own alcove but because the keyboard is now on its back (flipped), it will naturally fall out. What I did was to place the keyboard in its natural upright position when closing the inner and outer panel. And placing this screw bracket at closing the inner bracket.
Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
Grab the center of the front panel with two hands and lift to remove panel.
Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
It seems impossible to take the front panel out unless I break it. How did you do it?
I’m having the same issue. Did you ever figure out how to remove the front panel? Thanks
My experience 1st time doing it was terrible because of the double sided adhesive tape applied by the factory. So with gentle traction and plenty of patience it did finally give way. The second time around it was much easier.
Lay the speaker flat on the table and remove the four black 10mm J head screws with a J1 screwdriver.
1Commento della guida
What is the part number for the CDP-230r speaker replacement? I cannot find them online or through Casio. Thanks.
We have this model and the pitch is bending intermittently on it’s own. Do you think disconnecting the bending ‘wheel’ would stop this or is it more likely to be a faulty chip?
Thank you for any help!
Ryan - Replica
