Bowers and Wilkins T7 Battery Replacement
Introduzione
Vai al passo 1Use this guide to learn how to replace your battery for the Bowers and Wilkins T7 Bluetooth Speaker.
Cosa ti serve
Strumenti
Mostra di più…
Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
There are 8 screws in total.
FYI: I bought the Ifixit toolkit and sadly the screw driver isn’t long enough to remove the 4 middle screws.
What sizes are the screws exactly? I took mine apart and someone threw out the screws so now I need replacements.
Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
As the cover starts to come off, you can lift up using your hand.
I used a sharp knife. Note carefully where the seam is in the above diagram: on the back about 7 mm from the edge.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
Altre 9 persone hanno completato questa guida.
3Commenti sulla guida
Bravo ! Le choix de cet appareil symbolique !
No repair any repairing sentar
My model does not have screws in the front as indicates here. Not sure what to do now
thebolts - Replica
