Salta al contenuto principale
Bissell SpotBot Pet Control Panel Replacement
Anthony Bonvino
Anthony Bonvino e 2 altri collaboratori
Ultimo aggiornamento il 25 ott 2022
15 minuti
Moderato
Introduzione
Vai al passo 1
This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
Cosa ti serve
Strumenti
  1. Bissell SpotBot Pet Control Panel Replacement, Control Panel: passo 1, immagine 1 di 1
    • Start here.
    note to ifixit: we cannot edit the titles of each step
    Anthony Bonvino - Replica
  2. Bissell SpotBot Pet Control Panel Replacement: passo 2, immagine 1 di 1
    • Remove the container on the right side of the vacuum.
  3. Bissell SpotBot Pet Control Panel Replacement: passo 3, immagine 1 di 2 Bissell SpotBot Pet Control Panel Replacement: passo 3, immagine 2 di 2
    • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
  4. Bissell SpotBot Pet Control Panel Replacement: passo 4, immagine 1 di 1
    • Remove the left container of the vacuum.
  5. Bissell SpotBot Pet Control Panel Replacement: passo 5, immagine 1 di 1
    • Remove the four screws on the top of the device.
  6. Bissell SpotBot Pet Control Panel Replacement: passo 6, immagine 1 di 1
    • Lift the top of the device off once the screws are removed.
  7. Bissell SpotBot Pet Control Panel Replacement: passo 7, immagine 1 di 1
    • Unplug the ribbon cable from the motherboard.
  8. Bissell SpotBot Pet Control Panel Replacement: passo 8, immagine 1 di 1
    • Separate the top piece and flip it upside down.
  9. Bissell SpotBot Pet Control Panel Replacement: passo 9, immagine 1 di 2 Bissell SpotBot Pet Control Panel Replacement: passo 9, immagine 2 di 2
    • Remove the screws holding the motherboard in place.
  10. Bissell SpotBot Pet Control Panel Replacement: passo 10, immagine 1 di 2 Bissell SpotBot Pet Control Panel Replacement: passo 10, immagine 2 di 2
    • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team S7-G3, Banghart Fall 2017 Membro di Cal Poly, Team S7-G3, Banghart Fall 2017
CPSU-BANGHART-F17S7G3
4 Membri
4 Guide realizzate
1Commento della guida
Where can I buy the part?
Sue Loberger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 645
