Salta al contenuto principale
Behringer Eurolive B212D Control PCB Replacement
Troy W. Weber
Troy W. Weber e 4 altri collaboratori
Ultimo aggiornamento il May 1, 2022
30 - 45 minuti
Moderato
Guida fornita dalla comunità
Testo Confuso
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
The control PCB is attached to the inside of the back panel, and provides access to adjustment knobs and inputs and outputs for the B212D speaker.
Cosa ti serve
Strumenti
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Behringer Eurolive B212D Control PCB Replacement, Removing the Behringer Eurolive B212D Electronics Box: passo 1, immagine 1 di 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    Eurolive B212d back plate requirement
    Ashok Ahlawat - Replica
  2. Behringer Eurolive B212D Control PCB Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  3. Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 1 di 3 Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 2 di 3 Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 3 di 3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  4. Behringer Eurolive B212D Control PCB Replacement: passo 4, immagine 1 di 1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  5. Behringer Eurolive B212D Control PCB Replacement: passo 5, immagine 1 di 3 Behringer Eurolive B212D Control PCB Replacement: passo 5, immagine 2 di 3 Behringer Eurolive B212D Control PCB Replacement: passo 5, immagine 3 di 3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
  6. Behringer Eurolive B212D Control PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: passo 6, immagine 1 di 2 Behringer Eurolive B212D Control PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: passo 6, immagine 2 di 2
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
  7. Behringer Eurolive B212D Control PCB Replacement: passo 7, immagine 1 di 2 Behringer Eurolive B212D Control PCB Replacement: passo 7, immagine 2 di 2
    • Caution: The circuit board contains many capacitors that could cause serious injury if touched. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
  8. Behringer Eurolive B212D Control PCB Replacement, Control PCB: passo 8, immagine 1 di 1
    • Remove the 4 indicated 9/32" long screws with the #1 phillips head screwdriver
  9. Behringer Eurolive B212D Control PCB Replacement: passo 9, immagine 1 di 1
    • Remove the plastic cover.
  10. Behringer Eurolive B212D Control PCB Replacement: passo 10, immagine 1 di 1
    • Remove all three of the knobs by pulling them straight up.
  11. Behringer Eurolive B212D Control PCB Replacement: passo 11, immagine 1 di 1
    • Remove the 4 indicated 9/32" long screws using a #1 phillips head screwdriver.
  12. Behringer Eurolive B212D Control PCB Replacement: passo 12, immagine 1 di 1
    • Remove the 2 indicated 3/16" long machine screws with a #1 phillips head screwdriver.
  13. Behringer Eurolive B212D Control PCB Replacement: passo 13, immagine 1 di 1
    • The control PCB is free now, ready to be removed from the speaker's back panel.
Conclusione
Altre 4 persone hanno completato questa guida.
Troy W. Weber
Membro da: 03/29/12
1.449 Reputazione
6 Guide realizzate
5Commenti sulla guida
In Step 3 there are 2 more screws, along the side of the 'electronics box’.
The washer and nut securing the 1/4” socket also need to be removed.
plasticmojo - Replica
Where do I find a replacement control PCB for my B212A??
jcard2002 - Replica
Hi,i like to conect the board to another amp pcb but i dont now wich cable is for what ,do you now where is the power and the inputs?i already look for schematics but i didnt find anything about..thanx
Manolis Travlos - Replica
Frank Hazzard - Replica
Hi
My Behringer Eurolive B215D speaker has got a serious hissing sound when I plug just the power with no audio player connected. Anyone with any idea what can course this? Thanks.
john raphoto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 68
Tutti i Tempi: 11,301
