Behringer Eurolive B212D Control PCB Replacement
Introduzione
Vai al passo 1The control PCB is attached to the inside of the back panel, and provides access to adjustment knobs and inputs and outputs for the B212D speaker.
Cosa ti serve
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Remove the 4 indicated 9/32" long screws with the #1 phillips head screwdriver
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti5Commenti sulla guida
In Step 3 there are 2 more screws, along the side of the 'electronics box’.
The washer and nut securing the 1/4” socket also need to be removed.
Hi,i like to conect the board to another amp pcb but i dont now wich cable is for what ,do you now where is the power and the inputs?i already look for schematics but i didnt find anything about..thanx
Where do I find a replacement control PCB for my B212A??
Hi
My Behringer Eurolive B215D speaker has got a serious hissing sound when I plug just the power with no audio player connected. Anyone with any idea what can course this? Thanks.
Eurolive B212d back plate requirement
Ashok Ahlawat - Replica
