Salta al contenuto principale
Atari Flashback 6 Controller Board Repair
Kyle Albright
Kyle Albright e 2 altri collaboratori
Ultimo aggiornamento il May 30, 2024
20 - 40 minuti
Difficile
Necessarie Più Immagini
Passi mancanti
Introduzione
Vai al passo 1
This repair is for an Atari Flashback 6 controller. Over time, controller wiring can wear down and disconnect from the terminals. In this guide, we will demonstrate how to disassemble, re-solder the wires to the terminal, and then reassemble your Atari Flashback 6 controller. You can achieve all nine steps with little to no experience, as long as you have the right tools. Handle tools such as a soldering iron and exacto knife with care to prevent injury or controller damage.
Information on how to solder
Before you begin the repair, make sure to remove the batteries from the controller.
Cosa ti serve
Strumenti
Mostra di più…
  1. Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, immagine 1 di 3 Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, immagine 2 di 3 Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, immagine 3 di 3
    • If the controller currently contains batteries, please remove them before starting the repair.
    • Use a Phillips #1 screwdriver to remove single 1.5 mm-long screw securing the battery cover.
    • Lift the battery cover off.
    • Depress the spring that is in contact with the negative side of the battery to remove the batteries. Push down, and then remove batteries one at a time.
  2. Atari Flashback 6 Controller Board Repair: passo 2, immagine 1 di 3 Atari Flashback 6 Controller Board Repair: passo 2, immagine 2 di 3 Atari Flashback 6 Controller Board Repair: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the four 2 mm screws from the bottom of the Atari controller.
  3. Atari Flashback 6 Controller Board Repair: passo 3, immagine 1 di 2 Atari Flashback 6 Controller Board Repair: passo 3, immagine 2 di 2
    • Open the bottom case gently.
    • Do not rip it open as it is connected by a ribbon cable to the top case.
    • Remove the single 2 mm-long Phillips #1 screw securing the motherboard to the top case.
    • Use a spudger to gently remove the motherboard from the top case.
    • Be careful to avoid bending the board or the LED light.
  4. Atari Flashback 6 Controller Board Repair: passo 4, immagine 1 di 3 Atari Flashback 6 Controller Board Repair: passo 4, immagine 2 di 3 Atari Flashback 6 Controller Board Repair: passo 4, immagine 3 di 3
    • Separate the button board from the back panel.
    • Like a car battery, the negative terminal attaches to the black wire and the positive with the red wire.
    • You may have to strip the wires to expose the internal copper wiring.
    • Use a wire stripper to expose the internal wiring to secure a proper connection in the next step.
  5. Atari Flashback 6 Controller Board Repair: passo 5, immagine 1 di 2 Atari Flashback 6 Controller Board Repair: passo 5, immagine 2 di 2
    • Using a soldering iron can be dangerous. Because of the high temperature, please be sure to exercise caution when using this tool.
    • Attach the red wire to the positive terminal using the soldering iron, melting the solder to create a connection.
    • Attach the black wire to the negative terminal using the soldering iron, melting the solder to create a connection.
  6. Atari Flashback 6 Controller Board Repair: passo 6, immagine 1 di 2 Atari Flashback 6 Controller Board Repair: passo 6, immagine 2 di 2
    • Use a Phillips #1 screwdriver to replace the 2 mm screw that secures the motherboard to the top case.
    • Make sure to not pull on wires that are now attached.
  7. Atari Flashback 6 Controller Board Repair: passo 7, immagine 1 di 2 Atari Flashback 6 Controller Board Repair: passo 7, immagine 2 di 2
    • Reinsert the front panel into the groove of the outer shell.
  8. Atari Flashback 6 Controller Board Repair: passo 8, immagine 1 di 2 Atari Flashback 6 Controller Board Repair: passo 8, immagine 2 di 2
    • Replace the 2 mm Phillips #1 screws in the back panel to reassemble the controller.
    • After the back panel is secure, re-install the batteries, and replace the 1.5 mm Phillips #1 screw.
  9. Atari Flashback 6 Controller Board Repair: passo 9, immagine 1 di 1
    • Make sure to test the product by playing an Atari game. If buttons or directional toggle are not working, repeat steps 1- 8.
Conclusione
Ensure you test your controller when finished to verify the proper connection.
Kyle Albright
Membro da: 02/26/24
169 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 137
