Salta al contenuto principale
Atari Flashback 2 Reset and Select Button Replacement
Gabriel Robinson
Gabriel Robinson e 3 altri collaboratori
Ultimo aggiornamento il July 21, 2021
30 minuti
Moderato
Introduzione
Vai al passo 1
If the button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons to do so.
Cosa ti serve
Strumenti
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 3 di 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 3 di 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Conclusione
2Commenti sulla guida
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Replica
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 900
