Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Introduzione
Vai al passo 1A hard drive is an essential part of the laptop which is needed in order to store data. This guide will show you how to replace the battery of your Asus Vivobook Max X541SA-PD0703X.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Pull the Wi-Fi card out of the motherboard.
Remove the hard drive by pulling it towards the right, and removing it from the laptop case
I have an ASUS x451N. I changed the storage to an ssd since its very slow and now it doesn't boot. It just gets stuck in bios. It appears in the storage section but not on the boot menu. The ssd has an os and I have already tried to boot it in my pc and it works. I hope you can help me with this problem. Thank you!
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Thanx a million
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
