Salta al contenuto principale
Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Mayar Eskandarani
Mayar Eskandarani e 3 altri collaboratori
Ultimo aggiornamento il March 22, 2022
10 minuti
Moderato
Introduzione
Vai al passo 1
A hard drive is an essential part of the laptop which is needed in order to store data. This guide will show you how to replace the battery of your Asus Vivobook Max X541SA-PD0703X.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 1 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 2 di 3 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 1 di 2 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro di USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Membri
7 Guide realizzate
2 Commenti
Thanx a million
Eli Rottenberg - Replica
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
kevin ross s. rosento - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,712
