Introduzione
Upgrading or replacing the RAM (memory) on the Asus ROG G20CB can help boost system performance, especially for gaming, multitasking, or professional workloads.This guide will walk you through how to safely access, remove, and install RAM in the G20CB's compact chassis.
Important:
- The G20CB uses DDR4 SODIMM (laptop-style) RAM, not standard desktop DIMMs.
- Maximum supported memory depends on your CPU and motherboard model, but generally caps around 32GB (2x16GB).
Cosa ti serve
Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
Lift the CPU cooler out of the system.
Be sure to apply fresh thermal paste before reinstalling a cooler.
Gently push outward on the two retaining clips on either side of the RAM stick.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
