Salta al contenuto principale
Asus MeMO Pad HD 7 Battery Replacement
Julien Daigle
Julien Daigle e 9 altri collaboratori
Ultimo aggiornamento il July 26, 2024
15 minuti
Facile
Introduzione
Vai al passo 1
This guide is to show you how to replace the battery in an Asus MeMO Pad HD 7. This is a simple procedure that can be accomplished by anyone.
Cosa ti serve
Ricambi
Strumenti
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, immagine 1 di 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, immagine 2 di 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, immagine 3 di 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
    Important: Remove SD card first!
    Ola Eldøy - Replica
  2. Asus MeMO Pad HD 7 Battery Replacement: passo 2, immagine 1 di 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: passo 3, immagine 1 di 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, immagine 1 di 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, immagine 2 di 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, immagine 3 di 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
    I don't think you need to do this step (my motherboard came out and back in just fine, I just had to keep the battery cord out of the way, which is way easier than prying the whole thing out of there).
    Daniel Williams - Replica
Conclusione
Altre 14 persone hanno completato questa guida.
Julien Daigle
Membro da: 01/20/15
1.235 Reputazione
5 Guide realizzate
USF Tampa, Team 11-3, Blackwell Winter 2015 Membro di USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
4 Membri
5 Guide realizzate
4 Commenti
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - Replica
How did you fix the sd card port?
yanisstavrou - Replica
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - Replica
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 34
Tutti i Tempi: 21,996
