Apple Studio Display M7649 Logic Board Replacement
Introduzione
Vai al passo 1How to remove and replace the logic board. The logic board is like the main cpu of the display.
Cosa ti serve
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
Altre 2 persone hanno completato questa guida.
