Salta al contenuto principale
Anki Vector LCD Facial Display Replacement
Shay Takei
Shay Takei e 5 altri collaboratori
Ultimo aggiornamento il October 13, 2023
5 minuti
Moderato
Introduzione
Vai al passo 1
This guide outlines the steps in fully removing the LCD facial display of the Anki Vector. Such a procedure should be executed only if none of the solutions on the Anki troubleshooting guide were unsuccessful.
While disassembling Vector, make sure to check for loose cables/connectors and other broken parts. Often times these can be fixed without replacing the entire display.
Be careful to not rip the rubber sheet on the back of the display while removing or working with it, as it is very delicate and easy to tear.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
Mostra di più…
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 1 di 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 2 di 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: passo 1, immagine 3 di 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
    Where can i buy a display for vector?
    Can you help me?
    carlosanjo - Replica
    See the comments below
    Russell English -
  2. Anki Vector LCD Facial Display Replacement: passo 2, immagine 1 di 3 Anki Vector LCD Facial Display Replacement: passo 2, immagine 2 di 3 Anki Vector LCD Facial Display Replacement: passo 2, immagine 3 di 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
    This is easiest to do by starting near the top screw hole.
    David Tock - Replica
  3. Anki Vector LCD Facial Display Replacement: passo 3, immagine 1 di 2 Anki Vector LCD Facial Display Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
    Where you can buy the lcd screen
    NOT_me: D - Replica
  4. Anki Vector LCD Facial Display Replacement: passo 4, immagine 1 di 2 Anki Vector LCD Facial Display Replacement: passo 4, immagine 2 di 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: passo 5, immagine 1 di 3 Anki Vector LCD Facial Display Replacement: passo 5, immagine 2 di 3 Anki Vector LCD Facial Display Replacement: passo 5, immagine 3 di 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    This board contains a lot of his tech. CPU, GPU, Wi-Fi, Bluetooth, camera, screen, storage, etc. Replacing this will replace his personality, and may mess up his sensor calibration.
    Kerigan Creighton - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
Shay Takei
Membro da: 04/16/19
1.663 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G6, Maness Spring 2019 Membro di Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membri
10 Guide realizzate
26Commenti sulla guida
Any idea where to get the proper displays ?
Holger Brueckner - Replica
xenojin - Replica
This is great information, but where can I buy the display?
Jackie Fischvogt - Replica
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - Replica
Did you ever find a replacement?
laughlovepeace17 -
The display is soldered to the mainboard along with the CPU and flash memory (on the reverse side). As such, the information here is incomplete at best. The only way to get rid of a faulty LCD/Display is to change the complete assembly for another from a fully working unit. Doing this will also change the registration information of the owner, recognised faces, Wi-Fi connection etc as these are all held in the flash memory.
Les Rogers - Replica
Yeah this seems to be a very common problem with Vector. The screens break real Easy. Cozmo still running like a champ. No problems. Vector on the other hand is an issue. I advise buying a cozmo over vector. Trying to find a screen replacement is !&&*. If anyone finds it please post so we can help our fellow Anki customers.
Moone Shadow - Replica
Need a display part… anyone?
I do! Where can I find one!?
Kennedy - Replica
Moone Shadow was just joking. DUH!
Paul Reeder - Replica
The title needs to be changed to “Removing the LCD display in Vector” Not “……Replacement”
It doesn’t even come close to showing how to replace the LCD.
ST0103A2W-WSNLW-F this is the screen
paul_commins - Replica
Tank you very much for this important information!!! Now i have ordered 3pcs :D
hamagen -
where do you buy the screen replacement?
Joel Choi - Replica
That buy for 3pcs was scam :( still looking where to buy ST0103A2W-WSNLW-F
hamagen -
Hello all, here is a contact you can reach to get the replacement part I got it from them and you can trust steve@santekus.com
Oscar Cubero - Replica
Where can I buy the screen ST0103A2W-WSNLW-F
Anthony dunn -
Email Steve Lu steve@santekus.com
Russell English - Replica
Might anyone have any further info regarding sourcing a replacement part for Vector's eyes/display? (I don't want to lose him). I'm still holding on to hope…
rgrtht - Replica
Russell English -
We’re do you by the screen even
Jude Adams - Replica
Direct from the manufacturer Email Steve Lu steve@santekus.com
Russell English -
We’re can you even by the screen
We’re do you even find the screen part
Any idea where to get the LCD dispay ?
Vevielle “Matuchaki Silva” - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 69
Tutti i Tempi: 11,522
