Android tablet Nobis NB09 Screen Replacement
Introduzione
Vai al passo 1This is a guide on how to perform a screen replacement on a Nobis NB09 tablet. The screen is the most important part of the device when it comes to interacting with the tablet and users operating it in the first place. If the screen doesn’t work properly, then it becomes almost impossible to use the device at all.
It is advised to be cautious of possible shattered glass, and to use ESD-safe tools, as well as knowing how to properly use an anti-static mat and wristband.
Cosa ti serve
Remove the two 00 Phillips screws located on the right side of the tablet.
Use the plastic opening tools to loosen and then pry the back if the tablet off.
Remove the electrical tape covering the motherboard.
Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
Remove any remaining adhesive tape on the exposed area.
Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti2Commenti sulla guida
The digitizer replacement instructions was great. Thanks
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
