AmazonBasics B0050BPWBQ Activation Sensor Replacement
Introduzione
Vai al passo 1This guide shows how to replace an activation sensor that is no longer functional. The activation sensor is located in the middle of the feed slot so this guide will show you how to access this in order to replace it.
Cosa ti serve
Strumenti
Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
Locate the large white gears on the side of the shredding unit.
Remove two 15 mm Phillips #1 screws that hold the motor in place.
Locate the three washers on the metal triangle piece.
Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
Pull the metal triangle away from the gears.
Remove the middle gear from the shredding unit.
Remove the top gear that was located under the middle gear.
Remove the last 15 mm Phillips #1 screw from the plastic triangle piece on the side of the shredding unit.
Unhinge the sensor clamp from the blade by pushing with your thumb and pull the sensor away from the plastic side piece with the other hand to detach the activation sensor from the entire shredding unit.
After you go through all this, where do you get a new sensor for it?
I still can't believe I found this. Thanks to whomever took the time to make this guide.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
Excellent directions. Where can I purchase a new sensor?
