Salta al contenuto principale
Amazon Kindle DX Battery Replacement
Lori White
Lori White e 10 altri collaboratori
Ultimo aggiornamento il September 23, 2024
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to replace the battery in an Amazon Kindle DX. Kindle batteries can last many years, but it may be necessary to replace a battery if its performance is at an unbearable level. Rechargeable batteries of any kind can be tricky, and there can be many causes to the worsening of a battery’s health.
Some of these causes could be overcharging or undercharging. Overcharging may result from frequent usage of a device and undercharging may result from an extended period of time without access to a charger. Other possible issues may result from charging the battery to full capacity too often and also using the battery until it dies on a regular basis. Batteries are still not perfectly understood, however, so it is not often easy to pinpoint causes for deterioration of battery health.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Amazon Kindle DX Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the Kindle so the back is facing upwards.
  2. Amazon Kindle DX Battery Replacement: passo 2, immagine 1 di 1
    • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
  3. Amazon Kindle DX Battery Replacement: passo 3, immagine 1 di 1
    • Remove the plastic piece.
  4. Amazon Kindle DX Battery Replacement: passo 4, immagine 1 di 2 Amazon Kindle DX Battery Replacement: passo 4, immagine 2 di 2
    • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
  5. Amazon Kindle DX Battery Replacement: passo 5, immagine 1 di 2 Amazon Kindle DX Battery Replacement: passo 5, immagine 2 di 2
    • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
  6. Amazon Kindle DX Battery Replacement: passo 6, immagine 1 di 2 Amazon Kindle DX Battery Replacement: passo 6, immagine 2 di 2
    • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
  7. Amazon Kindle DX Battery Replacement: passo 7, immagine 1 di 2 Amazon Kindle DX Battery Replacement: passo 7, immagine 2 di 2
    • Remove the battery from the device.
Conclusione
Altre 13 persone hanno completato questa guida.
Lori White
Membro da: 09/28/16
577 Reputazione
3 Guide realizzate
USF Tampa, Team 1-5, Cagle Fall 2016 Membro di USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Membri
10 Guide realizzate
2 Commenti
In Step 5, you actually can insert the tool into the 2 holes on side, slide along the edge to loose the back cover, then slide the cover down to remove it. No need to pry on the edge, which is quite difficult.
dracodoc - Replica
Thank you very much for a comprehensive guide. Especially the measurements for where to insert the screwdrivers were very helpful! Kind regards - Jakob
anonymous 5048 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 123
Tutti i Tempi: 11,333
