Salta al contenuto principale
Amazon Fire Phone Display Replacement
Lissandra Ilcyn
Lissandra Ilcyn e 3 altri collaboratori
Ultimo aggiornamento il 5 ott 2016
20 - 30 minuti
Difficile
Introduzione
Vai al passo 1
Remove the display screen in order to fix a broken screen.
Cosa ti serve
Strumenti
Mostra di più…
  1. Amazon Fire Phone Display Replacement, Tape the screen: passo 1, immagine 1 di 1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: passo 2, immagine 1 di 3 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: passo 2, immagine 2 di 3 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: passo 2, immagine 3 di 3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Display Replacement: passo 3, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 3, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 3, immagine 3 di 3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Display Replacement, Remove Bracket: passo 4, immagine 1 di 1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    I kind of like the way the battery just “disappears” between step 5 and 6; mine was glued in with a REALLY good quality adhesive tape that took some chiseling to get free; happily, the battery didn’t explode, hopefully it will still work.
    vincentfasano - Replica
  5. Amazon Fire Phone Display Replacement, Disconnect Battery: passo 5, immagine 1 di 1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    Single hardest step, removing this battery takes both time and the jaws of life, it has an adhesive strip that will nearly RIP the battery or motherboard of the phone part, just keep careful while your at it, both mine and my wifes survived the tearing of this battery out, iv never been so sure I was breaking something while removing the battery but they went back together very easily once the devil adhesive let the battery go. This battery the the differential between a 1star difficulty and the 5star difficulty.
    Isaaru Narom - Replica
    I didn’t know Amazon made a phone it looks like iPhone when you opened it nice guide man
    Maxem - Replica
  6. Amazon Fire Phone Display Replacement, Micro-USB Port: passo 6, immagine 1 di 2 Amazon Fire Phone Display Replacement, Micro-USB Port: passo 6, immagine 2 di 2
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Display Replacement: passo 7, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 7, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 7, immagine 3 di 3
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Display Replacement: passo 8, immagine 1 di 1
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Display Replacement: passo 9, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 9, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 9, immagine 3 di 3
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Display Replacement: passo 10, immagine 1 di 2 Amazon Fire Phone Display Replacement: passo 10, immagine 2 di 2
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
    Boy, that could use a little more detail - pry camera from camera holder accompanied by a pic in which the fingernails and only the fingernails are in focus kind of leaves us wanting more…
  11. Amazon Fire Phone Display Replacement: passo 11, immagine 1 di 1
    • Lift off bottom plastic piece with flat antenna cables
    we really don’t have a feel for focus in this camera, do we?
    how to change the charging port
    hamzahassan22222 -
  12. Amazon Fire Phone Display Replacement, Display: passo 12, immagine 1 di 1
    • We recommend you clean your microwave before preceding to heat up the iOpener.
    • Place the iOpener in the center of the microwave.
    • Heat the iOpener for thirty seconds.
    • Be careful not to overheat the iOpener and always wait at least three minutes before reheating the iOpener
  13. Amazon Fire Phone Display Replacement: passo 13, immagine 1 di 1
    • Lay the iOpener on side 1 of the phone for 90 seconds before attempting to open the front panel
  14. Amazon Fire Phone Display Replacement: passo 14, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 14, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 14, immagine 3 di 3
    • Using the Suction Cup to slightly lift the screen, pry one opening pick into side of the phone.
    • Insert another opening pick next to the first one.
    • Slowly slide the two Picks to the corners of the phone.
  15. Amazon Fire Phone Display Replacement: passo 15, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 15, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 15, immagine 3 di 3
    • Place the iOpener on side 2 of the phone for 90 seconds.
    • Insert another pick into side 2 of the phone.
    • Slowly slide the pick to the next corner.
    • If necessary, reheat the iOpener. Don't reheat it more than once every 3 minutes.
  16. Amazon Fire Phone Display Replacement: passo 16, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 16, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 16, immagine 3 di 3
    • Place the iOpener on the 3rd side of the phone for 90 seconds.
    • Place a pick in the corner of the phone.
    • Slowly slide the the pick to the opposite corner of the phone.
  17. Amazon Fire Phone Display Replacement: passo 17, immagine 1 di 3 Amazon Fire Phone Display Replacement: passo 17, immagine 2 di 3 Amazon Fire Phone Display Replacement: passo 17, immagine 3 di 3
    • Place the iOpener on the last edge of the phone for 90 seconds.
    • Place the pick in the corner.
    • Slowly slide the pick to the opposite corner.
  18. Amazon Fire Phone Display Replacement: passo 18, immagine 1 di 1
    • Carefully separate the screen from the front panel of the phone by inserting the picks farther towards the center and pulling the screen off.
    • Slowly and carefully do this to avoid breaking, bending or shattering the screen.
    • If part of the screen isn't easily coming off try reheating the iOpener and placing it on the problem area.
  19. Amazon Fire Phone Display Replacement: passo 19, immagine 1 di 1
    • Remove the screen slowly.
    • Pull the cable out of the hole carefully.
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team 5-7, Maness Fall 2015 Membro di Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Membri
10 Guide realizzate
1Commento della guida
how to replace touch?
coolsaad2010 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,356
