Salta al contenuto principale
Amazon Echo Dot 3rd Generation Speaker Replacement
Elaina Moore
Elaina Moore e 3 altri collaboratori
Ultimo aggiornamento il August 11, 2023
5 - 10 minuti
Moderato
Studente al lavoro
Introduzione
Vai al passo 1
If the speaker of your Amazon Echo Dot 3rd Generation sounds muffled or is distorted in any way, the speaker may need to be replaced. Follow this guide to do so.
The cone shape of your Echo Dot allows your speaker to transmit Alexa's voice in an echo that should ideally carry through the room your device is in.
Check the speaker for other potential causes of sound disruption. Potential causes may include the mesh surrounding your Echo Dot being clouded with debris. Your Echo Dot could also be too close to another device such as a microwave that will cause interference.
Before attempting, make sure the Echo Dot is turned off and unplugged from the external power source.
Cosa ti serve
Strumenti
Mostra di più…
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: passo 1, immagine 1 di 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: passo 1, immagine 2 di 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: passo 1, immagine 3 di 3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: passo 2, immagine 1 di 2 Amazon Echo Dot 3rd Generation Speaker Replacement: passo 2, immagine 2 di 2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: passo 3, immagine 1 di 1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: passo 4, immagine 1 di 2 Amazon Echo Dot 3rd Generation Speaker Replacement: passo 4, immagine 2 di 2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: passo 6, immagine 1 di 3 Amazon Echo Dot 3rd Generation Speaker Replacement: passo 6, immagine 2 di 3 Amazon Echo Dot 3rd Generation Speaker Replacement: passo 6, immagine 3 di 3
    • Use a spudger to pry the speaker out of the device.
    Where do I find a new speaker?
    Matt Gallo - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
11Commenti sulla guida
Now where do I get the new speaker?
Philip Terry - Replica
Now WHERE do I get the new speaker?
vinodhkumar chejarla - Replica
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - Replica
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - Replica
This is only if the speaker isn’t actually blown.
GrantersG -
Where do we get the new speaker mother fc ker
Fcukermother - Replica
A link to a site selling replacement speakers, or a part number so we could search ourselves would have been helpful!
Neil Berry - Replica
Amazon does not sell any parts for the Echo devices. The best and probably only alternative is to buy a used Echo at eBay and use this guide to replace the speaker.
raymondjram -
The speaker is most likely a 1.5"/1.6" 40mm full range speaker. So far I have been able to reglue the cone to stop the rattle. Souring the correct speaker may be tough, or cost prohibited. Used Gen 3 is about $10-15, even a Gen 4 on sale is about $30.
Frame size 1.6 inches 40MM, thickness 18MM, voice coil size 26.5MM, installation opening 1.5 inches 38MM, diagonal gong distance 45MM, M1.5
Most likely 4ohm 8watt.
Jeffery Cates - Replica
Where to buy a new speaker?
Sahil Setia - Replica
you all are nasty as &&^&, get a life. Do a 2 second research on aliexpress.
Riccardo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 201
Tutti i Tempi: 6,247
