Amazon Echo 2nd Generation MIC Board Replacement
Introduzione
Vai al passo 1Follow this replacement guide if you are experiencing issues with the user interface of this device (e.g. buttons are not working, LEDs are dead, no voice recognition).
Cosa ti serve
Strumenti
Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Use a spudger to flip up the small flap on the ZIF connector.
Gently pull the ribbon cable out of the ZIF connector.
Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
Amp board may have two T10 screws holding tweeter speaker, do not remove.
Hi please where can find new main board? Thanks.
I am from India. If you find pls let me know
Dhanapal -
Use a spudger to lift up one of the small flaps on only one side of the female connector.
Pull on the wire toward the lifted side until the male connector is disconnected.
Remove the AMP Board.
How to replace the IC in this ?
Amplifire bord
Remove the four 30.0 mm T8 Torx screws in the corners.
Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
Remove the lid on top of the subwoofer.
Flip the device over and let the subwoofer fall into your hand.
Where can you get the replacement speakers?
Remove the four 16.0 mm T8 Torx screws underneath the speaker.
Flip the device over while supporting the front panel side.
Remove the front panel cover by lifting it.
Lift the MIC board over and lay it down against a surface.
Disconnect the ribbon cable from the MIC board and pull the board away.
Removing the rubber layer does not actually seem to be necessary.
jrhifixit - Replica
Where do you get the replacement Pcb
niall.mcgee1 - Replica
Rubber base removal not necessary.
Screws for first few steps may be T10, but a quality T8 driver may also work
Vicente Laluz - Replica
