Salta al contenuto principale
Amazon Echo 2nd Generation AMP Board Replacement
Eric Inman
Eric Inman e 4 altri collaboratori
Ultimo aggiornamento il 6 dic 2018
8 minuti
Moderato
Introduzione
Vai al passo 1
This guide will guide you through the process of replacing your AMP Board in your device. Use this guide if you are experiencing any power related issues and if you are certain this board is the cause of these issues.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • TR8 Torx Security Screwdriver
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 1 di 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 2 di 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 3 di 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
    Removing the rubber layer does not actually seem to be necessary.
    jrhifixit - Replica
    Where do you get the replacement Pcb
    niall.mcgee1 - Replica
    Rubber base removal not necessary.
    Screws for first few steps may be T10, but a quality T8 driver may also work
    Vicente Laluz - Replica
  2. Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 1 di 3 Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 2 di 3 Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 3 di 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
    Amp board may have two T10 screws holding tweeter speaker, do not remove.
    Hi please where can find new main board? Thanks.
    Frank Kofi Agyapong - Replica
    I am from India. If you find pls let me know
    Dhanapal -
    Where can I get new main board in India
    Dhanapal - Replica
  3. Amazon Echo 2nd Generation AMP Board Replacement: passo 3, immagine 1 di 2 Amazon Echo 2nd Generation AMP Board Replacement: passo 3, immagine 2 di 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
    How to replace the IC in this ?
    Asif Mohammed - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Eric Inman
Membro da: 10/08/18
337 Reputazione
3 Guide realizzate
Cal Poly, Team S4-G4, White Fall 2018 Membro di Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Membri
5 Guide realizzate
4Commenti sulla guida
Can anyone find a replacement board?
Tristan Parks - Replica
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - Replica
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - Replica
I have a need of one such a bord
Attmaram Nagorao Sugandhe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 35
Tutti i Tempi: 4,109
