Salta al contenuto principale
Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement
Drhaber
Drhaber e un altro collaboratore
Ultimo aggiornamento il December 3, 2018
Nessuna stima
Moderato
Introduzione
Vai al passo 1
PREREQUISITE
Cosa ti serve
Strumenti
Mostra di più…
  1. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: passo 1, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: passo 1, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: passo 1, immagine 3 di 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: passo 3, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: passo 3, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: passo 3, immagine 3 di 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 4, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 4, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 4, immagine 3 di 3
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 5, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 5, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 5, immagine 3 di 3
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: passo 6, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: passo 6, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: passo 6, immagine 3 di 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 7, immagine 1 di 2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 7, immagine 2 di 2
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 8, immagine 1 di 2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 8, immagine 2 di 2
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 9, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 9, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 9, immagine 3 di 3
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 10, immagine 1 di 1
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 11, immagine 1 di 1
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 12, immagine 1 di 2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 12, immagine 2 di 2
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
  13. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: passo 13, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: passo 13, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: passo 13, immagine 3 di 3
    • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    • Using a pair of tweezers remove the ribbon cable from its receptacle.
  14. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 14, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 14, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 14, immagine 3 di 3
    • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
  15. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 15, immagine 1 di 2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 15, immagine 2 di 2
    • Desolder the wires that connect the backlight to the motherboard.
  16. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 16, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 16, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 16, immagine 3 di 3
    • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
  17. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: passo 17, immagine 1 di 1
    • Carefully lift up on the motherboard from its housing.
  18. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: passo 18, immagine 1 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: passo 18, immagine 2 di 3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: passo 18, immagine 3 di 3
    • Gently pry the brackets holding the touch sensor to the LCD Screen
    • Do not bend the touch sensor to much as it may shatter.
Conclusione
Drhaber
Membro da: 02/10/16
985 Reputazione
7 Guide realizzate
USF Tampa, Team 4-1, Lacy Spring 2016 Membro di USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 608
