Salta al contenuto principale
Afterglow Wireless PS3 Controller Button Replacement
Aj Coello
Aj Coello e 2 altri collaboratori
Ultimo aggiornamento il December 30, 2019
20 minuti
Facile
Introduzione
Vai al passo 1
This guide will show the process of removing the back plate, vibration motors, and motherboard to access the buttons on the front of the controller.
Cosa ti serve
Strumenti
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, immagine 2 di 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, immagine 2 di 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Button Replacement: passo 3, immagine 1 di 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Button Replacement: passo 4, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 4, immagine 2 di 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
  5. Afterglow Wireless PS3 Controller Button Replacement: passo 5, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 5, immagine 2 di 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Button Replacement: passo 6, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 6, immagine 2 di 2
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
  7. Afterglow Wireless PS3 Controller Button Replacement: passo 7, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 7, immagine 2 di 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  8. Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 1 di 3 Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 2 di 3 Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 3 di 3
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
Conclusione
Altre 2 persone hanno completato questa guida.
Aj Coello
Membro da: 02/17/17
891 Reputazione
6 Guide realizzate
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 60
Tutti i Tempi: 1,498
