Salta al contenuto principale
Acer Iconia Tab A500 Battery Replacement
Kyle Libby
Kyle Libby e 4 altri collaboratori
Ultimo aggiornamento il June 4, 2014
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
This repair guide will help you with replacing the battery on your Acer Iconia Tab A500. Battery replacement might be needed when the battery inside the Acer Iconia Tab A500 is not functioning accordingly.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Acer Iconia Tab A500 Battery Replacement, Back Case: passo 1, immagine 1 di 1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Battery Replacement: passo 2, immagine 1 di 1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 Battery Replacement: passo 4, immagine 1 di 1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Conclusione
Altre 9 persone hanno completato questa guida.
Kyle Libby
Membro da: 04/07/14
1.006 Reputazione
7 Guide realizzate
Cal Poly, Team 7-23, Regan Spring 2014 Membro di Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Membri
19 Guide realizzate
2 Commenti
I just replaced my battery because it kept draining and the new battery started to charge but now it won’t charger at all so what can be wrong?
misscris0611 - Replica
Hi l have had my acer tablet for over 10 years and the acer iconiatab a500 as no been turned on for over 10 years and it is not cargering
Linda George - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 36
Tutti i Tempi: 11,560
