Salta al contenuto principale
Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement
Grecia Corrada
Grecia Corrada e 3 altri collaboratori
Ultimo aggiornamento il June 8, 2018
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
If a USB device is plugged-in correctly into the USB port and the Acer Aspire Switch 10 does not detect the USB device, then you may need to replace the USB port. Before you attempt to replace the USB port, please make sure that you have visited the troubleshooting page and followed the recommendations on the page. The troubleshooting page recommends that you make sure the USB device itself is working properly and that the USB port is clean. If you have attempted everything that the troubleshooting page recommends and the USB port still is not working properly, this guide will help you replace the USB port.
Cosa ti serve
Strumenti
  1. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: passo 1, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: passo 1, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement, USB Port: passo 1, immagine 3 di 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 2, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 2, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 2, immagine 3 di 3
    • Remove the yellow tape from the circuit board that is connected to the USB port.
    • Carefully unplug the two bundled cable connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 3, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 3, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 3, immagine 3 di 3
    • Flip up the ZIF connector that holds the larger ribbon cable in place with the opening tool.
    • Carefully unplug the larger ribbon cable by pulling on its blue tab.
  4. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 4, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 4, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 4, immagine 3 di 3
    • Flip up the small ZIF connector that holds the smaller ribbon cable in place with the opening tool.
    • Carefully unplug the smaller ribbon cable by pulling on its blue tab.
  5. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 5, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 5, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 5, immagine 3 di 3
    • Remove the 3, 2.5 mm screws on the circuit board.
  6. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 6, immagine 1 di 2 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 6, immagine 2 di 2
    • Remove the 2, 4.25 mm screws on the security tab.
  7. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 7, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 7, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 7, immagine 3 di 3
    • Lift the security tab so that it will be out of the way when you remove the circuit board.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  8. Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 8, immagine 1 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 8, immagine 2 di 3 Acer Aspire Switch 10 SW5-012-18MY USB Port Replacement: passo 8, immagine 3 di 3
    • Remove the circuit board by lifting it up with the opening tool.
    • The USB port is attached to this circuit board you have just removed. To replace the USB port on this piece, please go to the page How To Solder and Desolder Connections.
Conclusione
Grecia Corrada
Membro da: 03/19/18
1.134 Reputazione
6 Guide realizzate
Baylor, Team S3-G3, Williams Spring 2018 Membro di Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,755
