Introduzione
If your touch pad is not working and you have tried other troubleshooting options, it may need to be replaced. This guide will teach you how to replace the touch pad for this laptop. Be sure to fallow all of them steps in order. Make sure there is no AC power connected to the device before starting.
Parti
Nessuna parte specificata.
Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
Remove the two 6mm Phillips #0 screws from the fan.
Disconnect the fan from the motherboard.
Remove the four 6mm Phillips #0 screws from the heat sink.
Lift and remove the heatsink assembly from laptop.
