Salta al contenuto principale
Acer Aspire 5100 LCD Monitor Replacement
Brad Rollinson
Brad Rollinson e 8 altri collaboratori
Ultimo aggiornamento il 11 mag 2021
20 - 30 minuti
Difficile
Introduzione
Vai al passo 1
If your Acer Aspire screen (model 5100) isn’t producing a clear picture and instead outputs distorted images or intermittent/dead pixels, use this guide to replace the monitor.
The monitor transmits visual data to users through thousands of small pixels. A faulty monitor will transmit distorted or unclear images or no images at all.
Before using this guide, inspect the monitor for any debris that may be interfering with screen quality. Typically, any minute pieces of dust can be removed using an ESD-safe brush or small, damp towel. Be sure to completely shut down your laptop on and off at least two times to confirm that the faulty hardware is the monitor itself.
Before beginning, be sure to turn off your laptop completely and disconnect it from any external power source(s) or monitors if possible.
Cosa ti serve
Ricambi
Strumenti
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: passo 1, immagine 1 di 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: passo 1, immagine 2 di 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: passo 2, immagine 1 di 3 Acer Aspire 5100 LCD Monitor Replacement: passo 2, immagine 2 di 3 Acer Aspire 5100 LCD Monitor Replacement: passo 2, immagine 3 di 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: passo 3, immagine 1 di 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
    do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
    steve foss - Replica
    useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
    Valerio Vischio - Replica
    You do not need to remove the whole cover, in order to replace the keyboard.
    The description for this job is right.
    The switch plate cover just pops off.
    Screws revealed, secure the keyboard.
    Unclip the ribbon cable.
    Job done
    Richard -
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: passo 4, immagine 1 di 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: passo 5, immagine 1 di 2 Acer Aspire 5100 LCD Monitor Replacement: passo 5, immagine 2 di 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: passo 6, immagine 1 di 2 Acer Aspire 5100 LCD Monitor Replacement: passo 6, immagine 2 di 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: passo 7, immagine 1 di 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: passo 8, immagine 1 di 1
    • Lift up the monitor to detach it.
Conclusione
Altre 8 persone hanno completato questa guida.
Brad Rollinson
Membro da: 09/29/10
1.113 Reputazione
7 Guide realizzate
Cal Poly, Team 14-39, Forte Fall 2010 Membro di Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membri
10 Guide realizzate
1Commento della guida
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 15,578
