Salta al contenuto principale
ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
Jens Peter Andersen
Jens Peter Andersen e 2 altri collaboratori
Ultimo aggiornamento il December 13, 2017
30 - 45 minuti
Difficile
Passi mancanti
Introduzione
Vai al passo 1
Although it is extremely rare, the charging port on the laptop could be defective, misaligned, or broken if the laptop fails to show any signs of receiving power.
This guide should act like a "last resort" if all other methods of charging the laptop fails.
Please note that the use of soldering is required in order to remove the old charging port from the motherboard.
Cosa ti serve
Strumenti
Mostra di più…
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 2, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 2, immagine 2 di 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 3, immagine 1 di 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 3, immagine 2 di 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 3, immagine 3 di 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 4, immagine 1 di 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 4, immagine 2 di 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 4, immagine 3 di 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: passo 5, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: passo 5, immagine 2 di 2
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 6, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: passo 6, immagine 2 di 2
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: passo 7, immagine 1 di 1
Conclusione
USF Tampa, Team S5-G1, Walkup Fall 2017 Membro di USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,067
