Salta al contenuto principale
A Jammed SD Card Tray
Sqwerks
Sqwerks e 2 altri collaboratori
Ultimo aggiornamento il 23 set 2024
1 - 3 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This is for owners of the 3ds system that have a jammed sd port instead of disassembling the system you can just pop it open in just three steps.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, immagine 1 di 2 A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, immagine 2 di 2
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: passo 2, immagine 1 di 2 A Jammed SD Card Tray, Popping up tray: passo 2, immagine 2 di 2
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: passo 3, immagine 1 di 3 A Jammed SD Card Tray, Popping open tray: passo 3, immagine 2 di 3 A Jammed SD Card Tray, Popping open tray: passo 3, immagine 3 di 3
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: passo 4, immagine 1 di 3 A Jammed SD Card Tray, Remove sd card: passo 4, immagine 2 di 3 A Jammed SD Card Tray, Remove sd card: passo 4, immagine 3 di 3
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
Conclusione
Thanks and you’re welcome now you have free access to your sd card!
Sqwerks
Membro da: 10/31/22
551 Reputazione
1 Guida realizzata
The Sqwerks repair team Membro di The Sqwerks repair team
Community
1 Membro
2 Guide realizzate
4Commenti sulla guida
My first guide 😂
Sqwerks - Replica
its been officially accepted as of two months ago yahoo
Sqwerks - Replica
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - Replica
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,157
