Salta al contenuto principale
2008-2010 Mitsubishi Lancer Radio/CD Player Replacement
Carlos Esquivel
Carlos Esquivel e 5 altri collaboratori
Ultimo aggiornamento il August 29, 2024
30 - 45 minuti
Facile
Introduzione
Vai al passo 1
Tired of driving with a broken radio in your Mitsubishi Lancer and you don’t want to spend a small fortune having it replaced at a dealership? Save yourself the labor costs and simply do it yourself following this step-by-step guide.
In this guide I will be replacing the radio unit for a 2008 Mitsubishi Lancer. The model and part number of the radio unit may vary with year.
The model/part number for the radio unit is: MN141319/DY-3W69U
This guide may not apply to models with Rockford Fosgate or navigation systems.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement, 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 1, immagine 1 di 1
    • The only tool required for this install is a Phillips #2 screwdriver. Of course, you will also need the new replacement radio/CD player unit that you will be installing.
    • Make sure that the car is not on before proceeding since we will be accessing some electrical components. However, you do not need to disconnect the car's battery.
  2. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 2, immagine 1 di 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 2, immagine 2 di 2
    • Using both hands, apply inward pressure to the sides of the glove compartment until the compartment is free to slide out.
    • The clips on the side of the glove compartment must be freed.
  3. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 3, immagine 1 di 1
    • Remove the attached plastic arm by simply pulling outward so that the arm snaps out of its socket.
  4. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 4, immagine 1 di 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 4, immagine 2 di 2
    • The glove compartment can now be removed completely by raising it off its hinges.
  5. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 5, immagine 1 di 1
    • Using the Philips #2 screwdriver, remove a 15 mm screw located just above the glove compartment damper piston.
  6. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 6, immagine 1 di 1
    • Carefully remove the plastic trim by pulling outwards.
  7. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 7, immagine 1 di 1
    • Using a Philips #2 screwdriver remove a 15 mm screw from the trim piece.
  8. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 8, immagine 1 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 8, immagine 2 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 8, immagine 3 di 3
    • Using both hands, carefully pull the trim outward section by section.
    • The dashboard and decorative trim are attached to each other, so they will come out as one unit.
    • When pulling out the trim start from the right and work your way toward the center console.
  9. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 9, immagine 1 di 1
    • Optional: If you choose, you can remove the harness shown. (See directions on Step 12 for removing a harness clip.) Otherwise you can simply rest the fixture on top of the shift knob.
  10. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 10, immagine 1 di 1
    • Using a Philips #2 screwdriver remove four 12 mm screws attached to the mounting bracket.
  11. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 11, immagine 1 di 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 11, immagine 2 di 2
    • Pull out the radio unit to expose the connections behind it.
  12. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 12, immagine 1 di 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 12, immagine 2 di 2
    • Remove the black antenna connection by simply pulling it out.
  13. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 13, immagine 1 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 13, immagine 2 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 13, immagine 3 di 3
    • Remove both the large and small wire harnesses by firmly pressing in and holding the retaining clip.
    • While continuing to hold down the retaining clip, firmly pull the harnesses out.
    • Do not pull harnesses out by the wires, as you may damage or break the wires. Instead pull out by the white plastic harness.
  14. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 14, immagine 1 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 14, immagine 2 di 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: passo 14, immagine 3 di 3
    • You are now ready to replace your radio with your new unit.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 12-1, Green Winter 2015 Membro di Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Membri
8 Guide realizzate
5 Commenti
Thx. Saved me hrs of wrongful disassembly. Lol
Phil - Replica
Any Mitsubishi radio code can be recovered for free by online generating tool : https://www.radiocodescalculator.com/mit...
Blaze Angelov - Replica
Hi I own a 2008 Mitsubishi lancer just brought it CD player doesn't work only radio so wondering where I can buy a new stereo thanks. Or a way to fix mine it's like it's not working at all turn onto CD mode but won't even try read
JAD BLAXLAND - Replica
Had the same problem with my 08 lancer. Replaced with a refurbished unit.
sanjurjo54 -
If you break some of the white clips like i did, the replacement part number from Mitsubishi is MR402859
gregshep - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 140
Ultimi 30 Giorni: 215
Tutti i Tempi: 21,216
