Salta al contenuto principale
Google Pixel Slate Screen Replacement
Spencer Alonge
Spencer Alonge e 8 altri collaboratori
Ultimo aggiornamento il December 21, 2021
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to remove and replace the screen from Google Pixel Slate.
A screen replacement is necessary if your screen display is cracked or damaged that can inhibit the view and touchscreen functionality of the device.
Before you start, make sure to completely turn off the power of the phone and disconnect all external power sources.
Please be aware that the replacement of the screen must be done with great care, as you can potentially damage other parts of the device.
Cosa ti serve
Strumenti
  1. Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Screen Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Screen Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
13 Commenti
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - Replica
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Replica
me too! the resource replacement link plz!!
gabriela urquidi - Replica
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 5,084
