Salta al contenuto principale
Indice dei contenuti
Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Toshiba Satellite p875-s7200 Troubleshooting
This is a troubleshooting page specifically for the Toshiba Satellite p875-s7200 laptop. It covers a range of problems that are typical of this product as well as multiple quick fixes.
Toshiba Satellite Is Running Slow
Your laptop is loading slower than usual.
Too Much Clutter On Hard Drive
Computers can be slowed down by many different conditions one of the most common being a cluttered hard drive. The easiest way to solve this problem would be to delete unnecessary files from your computer; another quick solution is to empty the recycle bin.
RAM Is Depleted
In order to run quickly, computers store information from recently opened apps in the Random-Access Memory (RAM). The easiest way to fix RAM issues is to restart the computer, which will clear the RAM. If the issue becomes frequent, you may need to upgrade your RAM.
Laptop Screen Is Too Dim
Your laptop screen appears to be on but isn't bright.
Settings Need Adjustment
There might be a few settings options you might have to check. First make sure the brightness is turned up by either using the shortcut keys or adjusting the settings of the computer. The laptop may be in power saving mode, trying to conserve the laptop’s battery; ensure the laptop is plugged in, fully charged, and not in power saving mode.
Screen is cracked
If you have dropped or damaged the laptop, and a cracked/shattered image appears on the screen, you may need to replace it.
Screen isn't working
If you have checked these items and the screen is not functioning, you may need to replace it.
Can’t Access Hard Drive
You have been trying to get to your stored information.
Hard Drive Connection Points Not Solid
With the frequent movement of laptops, or the occasional drop, hard drives can become unseated from the pins in the case. This problem is not severe and can be fixed by opening the computer, taking the hard drive out of the slot, then putting it back into its slot. If the hard drive doesn’t show up after turning the computer on, you may need to replace it.
Hard Drive Is Faulty
Hard drives tend to stop working or fail after a while (especially if it is an HDD, Solid state drives don’t tend to fail as often because they don’t contain moving parts). Multiple beeping noises or clinking noises are common indicators of failure. If failure has occurred, you will need to replace the hard drive.This is a last resort troubleshooting solution because new hard drives can be expensive depending on the size. After replacing the hard drive, you should contact a professional to retrieve the important data from the corrupted hard drive.
Discs Aren’t Playing Correctly
You have been trying to play discs but cannot get them to work.
Dirty Or Damaged Movie/Program Disc
Try using a different movie/program disc. If a different disc plays normally, the first disc is likely dirty, scratched, or has label damage. If the disc is dirty, clean it with a soft lint-free cloth and try it again. If there are scratches, they can likely be repaired with a CD scratch repair kit. (CD scratch repair kits are sold by most electronic stores and are relatively inexpensive). If there is damage on the label side of the disc, it cannot be repaired.
Dirty Disc Reader
Dust may have accumulated on the disc reader, making it difficult for proper reading of the game disc. If the reader needs to be cleaned, use a cotton swab and a proper lens cleaning solution that can be found in any electronic store.
Disconnected Disc Drive
The disc drive is the device within the computer that allows your laptop to read a disc. There is a chance that the disc drive is not being recognized by your laptop; verify this under the device manager in the laptop settings. If connected but disc is still not working, you may need to replace the entire disc drive.
Disc Drive Is Faulty
Disc loading errors, skipping, and freezing often result from a faulty disc drive. Some symptoms include:
• No spinning or abnormal spinning of the disc
• Loud tracking noises
• Frequent error messages when running software
If your device encounters any of these problems, you should replace the disc drive.
Danny Amado
Membro da: 10/29/18
823 Reputazione
5 Guide realizzate
Baylor, Team S1-G3, Williams Fall 2018 Membro di Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 410
