Salta al contenuto principale
« Torna a Tutte le Storie
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Immagine Storia
iPhone 4 Verizon Rear Panel Replacement
5 minuti
Easy
Il Mio Problema
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
La Mia Riparazione
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Il Mio Consiglio
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
Immagine P2 Pentalobe Screwdriver iPhone
$5.99
Immagine iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel
$9.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 8
Tutti i Tempi: 204
