Introduzione
Vai al passo 1This teardown guide shows step-by-step how to take apart your PSP 3000
Cosa ti serve
Strumenti
The first picture is a view of the front of the PSP-3000. The second picture is of the back.
Using a spudger or fingernail (spudger set available at iFixit) http://www.ifixit.com/Tools/Metal-Spudge... peel back the warranty sticker that was behind the battery.
Using a Phillips #0 screwdriver (screwdriver available at iFixit Tools), Unscrew all four screws from the back of the PSP.
Two from behind the battery.
And two on the right side of the PSP.
Using a spudger or fingernail, flip the small brown locks on the four ribbon cable connectors up.
WARNING! Be carefull removing the small ribbion from the LCD connector, it is very delicate. Using a spudger lift the black plastic up, NOT the white part on the connector!
Pull all four ribbon cables out, and remove the LCD screen and homebar from the PSP.
9 Commenti
Does a PSP have any bearings inside of it?
No ball bearings. Thumbsticks are probably just Lubed plastics rubbing against eachother
mahonen -
This has inspired me to build my own PSP. I had one as a child, and want one now for the nostalgia. Thanks!
