Not spraying during normal cycle.
Whirlpool WDF560SAFM2.
New circulation pump
Filter Clear, Spray arms clear, Manifold clear, pump inlet/return clear.
Ample water when running
No Error Codes F- E-
Works perfectly during a maintenance cycle but water only dribbles out of both sprayers on any normal cycle
Any ideas?
Questa è una buona domanda?
Hi @kentrhodes44149
Do both arms rotate albeit slowly?
If only one moves it could be a faulty diverter or diverter disc.
Have you tried just a water only wash i.e. no detergent or rinse aid to check if the arms rotate normally i.e. strong water pressure out of arms?
If they do it could be a problem with air getting into the pump from the dispensers
da jayeff Condividi
It might be the rotating diffuser plate. It sits firmly on the motor axis and doesnt look worn at all but i will find it askew when I open it up to look at it. It anything supposed to hold it down? There arent any clips or catches that seem to hold it in place
da Kent Rhodes Condividi
