Salta al contenuto principale
Console per videogiochi prodotta da Sony Computer Entertainment; la PlayStation 4 Slim (serie CUH-2000) è un modello sostitutivo più sottile della PS4 originale. Annunciata il 7 settembre 2016.
Controller/Console damaged while playing
This is a weird problem to have, but a friend's son had a temper tantrum while playing on the PS4 slim and tried wrenching and pulling off the left analog stick while the game was running. Not only that, he threw it a few times quite hard on the floor and slammed it repeatedly on the ground! While all of this was happening, the game was noticeably glitching - it was God of War 3 Remastered, and it got stuck in a weird state in Photo mode, and then the console reverted to the operating system view and glitched visibly as the controller was being damaged! I went back and restarted the console and used a separate controller. Things seem to be working fine, but do you think there's a danger of a power surge or something having affected the PS4 slim hardware permanently? I don't remember if the controller was connected using Bluetooth or the USB cable while all of this was happening. The original controller is now damaged beyond recognition, but the console seems to be running fine with the new controller. Is there something I should look out for, with respect to damage or how games are running? I was also wondering if the Smart TV itself could be damaged as well.
Summary: I'm primarily concerned about the fact that the left analog stick was being wrenched out while the game was running, and the fact that it was slammed so many times on the ground, and also thrown, which caused the games and the operating system to glitch on screen, and whether it caused any lasting damage to the console or the television.
Again, I understand this is a weird problem to have, and my heart is broken (I kept the console in a fairly pristine state), so any advice or help is appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hello, @arthasligh65436
It's mostly hardware damage to the PS4 Controller, so you got lucky there! If there was any visible damage to the PS4 Console itself, then I would go into more depth. And there is almost no risk of a power surge if multiple inputs are being done wired or wirelessly, as well as rapid connection loss. Damage to a controller almost never corresponds to damage to a console. However, if you encounter anything strange while you continue to use the PS4 as normal, don't hesitate to give us an update!
T
Punteggio 1
1 Commento:
I agree! It’s most likely only the controller that got damaged. PS4 should be fine. Sure it was glitching due the controller, but this should not harm the PS4 :)
da Condividi
Aggiungi la tua risposta
Arthas Lightbringer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 66
