Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per i controller Joy-Con 2 del Nintendo Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Immagine
Immagine
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Immagine
Immagine
Thank you for reaching out!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi!
Glad that you figured it out :)! Have a great day!
da Condividi
Thank you! I was about to just accept I busted my controller until I found this.
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Please follow this to step 13: Sostituzione del joystick del Joy-Con 2 (sinistro)
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Punteggio 1
Aggiungi la tua risposta
David Sandoval Galiana sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 18
Ultimi 30 giorni: 104
Tutti i Tempi: 168
