Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per Steam Deck OLED, un aggiornamento del 2023 della popolare console videogame portatile prodotta da Valve. Rilasciata il 16 novembre 2023. Identificata dal numero di modello 1030.
Left joystick having drift/input problem
I had a tiny bit of water spill on steam deck turned it off immediately for 4 days turned it on as I was told and everything is working fine except the left joystick keeps going left but when I switch to desktop mode and use the keyboard it goes up and down fine even pushing down on it to turn on and off caps lock works fine just can’t go left or right is there a way to fix the joystick or anything I’m not trying to buy a whole new steam deck I just bought this one not even a full year ago
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi!
First, open it up and check for corossion inside. If you find any, clean it with isopropyl alcohol. For the left stick, clean it with isopropyl alcohol anyway and see if that fixes it.
If not, then replace the left joystick and see if that will fix it!
Guide: Sostituzione joystick sinistro Steam Deck OLED
Please let us know how it goes!
Punteggio 0
Aggiungi la tua risposta
Lamar Stapleton sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 30
Tutti i Tempi: 72
