Salta al contenuto principale
Il 9520 è un modello del 2022 della linea XPS, con un display da 15,6 pollici disponibile con risoluzione da 1920 x 1200 a 3840 x 2400, oltre a processori Intel i5, i7 o i9. La GPU è Intel Iris Xe, supportata da una scheda grafica dedicata GeForce RTX.
Battery replacement for XPS 9520
Hello. I bought a refurbished Dell Xps 9520 and I want to replace the battery. Few weeks ago I replaced the cpu and gpu thermal paste and tool a picture of the battery.
Immagine
I found the battery here, on ifixit.com but when I check the compatibility It says: This does not fit Dell XPS 15 9520.
So, does it fit? Or not...
Thanks
Update (09/18/26)
Here
Immagine
Immagine Replace a 7544 mAh battery compatible with a Dell 69KF2 laptop battery. 86 Watt Hours (Wh). 11.4 Volts (V). Part #DVG8M, 8FCTC, P8P1P
Prodotto
Dell 69KF2 Battery
$79.99
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Hi! I opened a moderation vote to move this question to the iFixit Meta forum, where this question is a little better suited as this is more of a customer support question. If you do not get an answer within a few days I would suggest contacting the iFixit support directly to guarantee an answer which you can do at https://www.ifixit.com/Support
Hope this issue is resolved soon,
Cheers
da
Hi @liviurabac
Where does it state on the page you linked that it is not compatible?
I can't find any mention of the model number you listed on the page and when using the Compatibility search box on the page to look for your model it just says no results, which usually means that it can't find it and not that it isn't compatible.
You can check if it physically fits by looking at the image of the battery on the page you linked and compare the position and number of screw mounts on the battery against what the battery in your laptop has.
da
Aggiungi un commento
1 Risposta
Hi @liviurabac
That is interesting because on the USA ifixit parts page it doesn't show it. It shows a different laptop make and model. (see image below)
I think that if that is the model number on the battery in your laptop then it should work. Perhaps it's a misprint on the ifixit site that you're on.
A search online for Dell XPS 15 9520 battery all the results show the same battery model number i.e. 69KF2
As I suggested, check the screw mounts on the original battery against the image to see if they line up
Immagine
(click on image)
Punteggio 0
Aggiungi la tua risposta
Liviu Rabac sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 79
Ultimi 30 giorni: 79
Tutti i Tempi: 79
