Salta al contenuto principale
How do I change my screen
How do I change my computer screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @harvelgordon
Here's the maintenance and service guide for the laptop.
Go to p.56 (64 of 92 pdf) in the manual to view the procedure to remove and disassemble the display assembly so that the LCD panel can be replaced.
There are 5 LCD panels that can be used in the model. Go to p.20-p.21 (28-29 of 92 pdf) in the manual Item #3 to find the HP part numbers for the LCD panels.
Search online using the applicable part number only for the panel in your laptop to find suppliers that suit you best. Usually the part number can be found somewhere on the back of the LCD panel, if you wish to verify that it is the one you want before ordering.
Punteggio 1
Aggiungi la tua risposta
Harvel Gordon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 20
Tutti i Tempi: 20
