Salta al contenuto principale
Il visore per realtà mista Meta Quest 3 è stato rilasciato il 10 ottobre 2023 ed è il successore diretto del Meta Quest 2 e, per molti versi, il successore spirituale del Meta Quest Pro.
Update and restart loop
I have bought this device used, so I have no warranty.
The device keeps updating and restarting, side load update didn't work because the site said incompatible device or something like that, and factory reset didn't work either (it reseted and still had the loop).
Is there some different manual way to fix that, maybe somehow completely wiping the quest 3's SSD and manually installing the OS?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
It sound like firmware/NAND issues.
It would be very difficult to fix this.
I would check with Meta their support to see what options you have.
Anyway, if you would like to know more about it's NAND, you can follow this: Identificazione dei chip del Meta Quest 3
Hopefully Meta does have a solution for you or maybe you can sent it in, so that they can refurb it.
Sorry for the bad news.
Punteggio 1
Aggiungi la tua risposta
Aleksandr Muchin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 6
Tutti i Tempi: 48
