Salta al contenuto principale
Informazioni per la riparazione delle lavastoviglie Whirlpool.
Circulation pump ohm readings
wdf320padw0 dishwasher does not cycle after water fill. Pulled the circulation pump and 200 setting shows OL. But at 200k shows 89-96 ohms. Bought 2 new pumps and the same readings occur.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @abelsaiz
Looking at the wash/rinse strip circuit on p.4 of the tech sheet for the dishwasher, the wash motor should be 5-15 Ohms.
If you're measuring the wash motor directly on the motor terminals 1 & 3 with the harness wiring disconnected have you checked that you've got the correct wash motor?
According to Item #4 on p.13 of the parts list the wash motor part number is W10529161 which according to most suppliers has been superseded by W11133712 (example only)
Punteggio 0
Aggiungi la tua risposta
Abel Saiz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 26
Tutti i Tempi: 82
