Salta al contenuto principale
La Camry serie XV40 è stata presentata al North American International Auto Show del 2006 insieme a una versione ibrida ed è stata messa in vendita a marzo 2006 per l'anno modello 2007.
Air-conditioning temperature control issue
The automatic climate control system does not function properly upon starting the vehicle. The AC fails to blow cold air at standard temperature settings (e.g., 22°C / 72°F) and will only begin cooling if the thermostat is manually forced to its absolute lowest setting ("MAX AC" / "LO"). Once the cabin cools down under this maximum setting, the temperature can then be adjusted back up to a preferred comfortable level, and it will hold that temperature normally for the remainder of the drive. This issue occurs every time the car is started.
Questa è una buona domanda?
Punteggio 0
1 Commento
This can be an expensive, time consuming repair performed by repair shops or dealer, or by yourself if you are comfortable using service manuals and can diagnose, troubleshoot and use tools including a multimeter. You can always get an estimated cost from several repair shops and dealer otherwise you might consider it more expensive than its worth and accept this as a working solution on an aging vehicle.
da
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @vajirampap51825
Get the vehicle's OBDII port scanned with a scantool and check if any DTC codes pertaining to the Air conditioning system have been stored by the A/C amplifier module. The code will tell you what the problem might be.
You could always use the A/C self diagnosis procedure and check what that shows as well.
Punteggio 1
I am guessing that the max cool position bypasses the sensor. Why it starts working normally after that ??
You would likely do better on toyotanation.com
Punteggio 0
Aggiungi la tua risposta
vajiram papanaidu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 13
Ultimi 30 giorni: 55
Tutti i Tempi: 55
