No light when charging
Unit sat for along time and now it won't charge
Questa è una buona domanda?
@alantordoff possibly an issue with the battery having discharged below it's charging threshold. That basically means that the battery has discharged to a point where it no longer accepts a charge. I would start of with a new battery. Use this guide Sostituzione batteria Sony WH-1000XM4 for that.
A new battery will also give you a known well starting point should it become necessary to troubleshoot further. If the new battery doesn't fix this, you will need to check the charging port and charging circuit.
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 38
Tutti i Tempi: 80
