Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per Steam Deck OLED, un aggiornamento del 2023 della popolare console videogame portatile prodotta da Valve. Rilasciata il 16 novembre 2023. Identificata dal numero di modello 1030.
Searching For a Motherboard replacement
Had an issue with the USB-C port going out completely, bought parts and attempted to hot air solder the old port off and unfortunately instead of the port coming off several other components decided to make a break for it. Anyone have an idea where I could get a new board? Looks like its MODEL :F7G DA0F7GMBAE0 REV: E if that's right.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Not easy to find and they are relative expensive.
You can find as example one here (Please double check your model FIRST, or contact them): https://www.aliexpress.us/item/325681062...
and here also one as example (Be aware this model WON'T fit yours): https://www.ebay.com/itm/266528012456?no...
The Seller on Ebay is selling more different models for the Steam Deck. I advise to contact them.
I'm afraid that those are the only options...
Punteggio 1
Aggiungi la tua risposta
FoxxTech sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 35
Tutti i Tempi: 195
